Date/Time: Sun, 19 May 2024 23:56:55 +0000
What are these multiple bars on the chart?
View Count: 544
[2018-07-27 05:51:31] |
User905484 - Posts: 1 |
My ESU8 233-Trades chart prints funny multiple bars from time to time and it makes the chart hard to understand. Can you explain this to me and help me with a solution to eliminate this confusion? I am also including my NQU8 chart. I have indicated the problem areas with green ellipses on the charts. In most cases the first bar in the series has a time like 19:49:44 and the remaining bars all have time stamp 19:50:00. Or the first bar is time stamped 20:00:56 and the other bars are time stamped 20:01:00. These are not the only times these problems print, they are only examples from today. Note that I have four charts up: ES, NQ, RTY, and YM and they all seem to pause a second or two then all print a series of bars coincidentally. http://www.sierrachart.com/image.php?Image=1532670460653.png http://www.sierrachart.com/image.php?Image=1532670554738.png Thanks. Richard |
[2018-07-27 07:06:53] |
The reason for this is because Sierra Chart is not set for a tick by tick data configuration. Just follow through the instructions here: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
