Date/Time: Mon, 06 May 2024 11:12:33 +0000
Volume profile not working as it should
View Count: 1859
[2018-07-18 12:29:20] |
Scipio - Posts: 5 |
Hi, The volume profile worksfine on my stationary, but gets all out of wack on my lap. See screens. Suggestions? http://www.sierrachart.com/image.php?Image=1531916889549.png |
.XBT-BMEX 60 Min #3 2018-07-18 12_23_58.750.png / V - Attached On 2018-07-18 12:25:00 UTC - Size: 37.18 KB - 314 views Attachment Deleted. |
[2018-07-18 16:45:10] |
For volume profiles you really should be using this symbol instead: XBTUSD-BMEX And refer to this particular setting here to make sure it is set correctly: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-26 11:25:06] |
Scipio - Posts: 5 |
Thanks, XBTUSD worked better. Another question. The ETHXBT, BCHXBT etc. work fine with my Mboxwave indicators on daily timeframe, but when I put it on 4 hours and below the indicators malfunction. They work fine on all timeframes with XBTUSD. IS it something wrong in the feed? http://www.sierrachart.com/image.php?Image=1532604278492.png http://www.sierrachart.com/image.php?Image=1532604233489.png |
[2018-07-26 12:01:53] |
Scipio - Posts: 5 |
Checked it with ordinary volume, which malfunctions on the daily. http://www.sierrachart.com/image.php?Image=1532606468234.png |
[2018-07-26 17:58:16] |
You need to contact the developer of those studies about this: Another question. The ETHXBT, BCHXBT etc. work fine with my Mboxwave indicators on daily timeframe, but when I put it on 4 hours and below the indicators malfunction. They work fine on all timeframes with XBTUSD. IS it something wrong in the feed?
[2018-07-26 18:47:41] |
Scipio - Posts: 5 |
I have been in contact with him and was adviced to do a new installation of both Sierra and the indicators which I did. I don't think the issue lays there, since the developers indicators works 100% on all timeframes when I pick random symbols from bitfinex, bitstamp and poloniex or use XBTUSD from Bitmex. The only symbols giving these problems are all from Bitmex. Also as I pointed to in my last post the standard volume study which comes with Sierra also malfunctioned with the bitmex datafeed, here are examples with BCH from Bitmex and Bitfinex. The settings are identical. The same fault applies to LTCXBT, ADAXBT etc. Then as you see from the third picture it works fine on BCHU18, but I cant use those charts. http://www.sierrachart.com/image.php?Image=1532630348363.png http://www.sierrachart.com/image.php?Image=1532630373928.png http://www.sierrachart.com/image.php?Image=1532630824574.png |
[2018-07-27 01:04:22] |
A new installation of Sierra Chart is completely unnecessary and does not help this case. Also as I pointed to in my last post the standard volume study which comes with Sierra also malfunctioned with the bitmex datafeed This is an incorrect conclusion and can never possibly be true.If the Volume data of whatever symbol is not what you expect, then do not use those symbols. We cannot provide further help with this and we are declining further support. So in other words, it is the Volume data of those symbols is not what you expect. It is what it is. But Sierra Chart is accurately reporting the volume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-27 03:44:23
[2018-10-27 13:03:52] |
User734899 - Posts: 1 |
Hi support, My volume profile does not work correctly on XRPZ18-BMEX. (But on XBTUSD-BMEX everything works well.) See the image please. Please, help! |
sierra problema.JPG / V - Attached On 2018-10-27 12:49:35 UTC - Size: 96.45 KB - 323 views Attachment Deleted. |
