Date/Time: Sun, 05 May 2024 13:21:38 +0000
Auto Snap on Point and Figure chart does not snap to the high/low of the bar
View Count: 1260
[2018-07-13 16:49:37] |
opmetal - Posts: 65 |
I draw rays anchored to the high or low of a point and figure bar. I'd like to transition from the P&F study to the "Point And Figure Bar (BoxSize in ticks - ReversalSize)" Bar Period Type but auto snap will not snap to the "point and figure" high or low, it snaps to the underlying bar high or low which is often not the same. This is not the case when using the Point and Figure Chart study, where it correctly snaps to the P&F high or low (and it would be a pain to have to manually adjust the anchors for every ray). Is there a setting for this? Thanks.
[2018-07-15 09:33:23] |
We will look into this. We can solve this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-15 09:34:00
[2018-08-03 21:57:33] |
Thank you for implementing this feature. However, the snapping to high/low no longer works for charts with the P&F study. Maybe this can be fixed by allowing a daily/weekly/monthly P&F bar period type so that everyone can fully migrate off the study?
