Date/Time: Fri, 03 May 2024 11:11:08 +0000
DOM issue - Overcrowding of Numbers on Price Ladder along with Bids and Asks
View Count: 1101
[2018-07-13 01:55:07] |
User344276 - Posts: 65 |
When I minimize the DOM in order for it to fit on my screen, the numbers on the price ladder along with the Bids and Asks are overcrowding. Instead of showing consecutive numbers on the price ladder in the order of 24951, 24952, 24953, 24954, etc, I'm seeing the numbers displayed in multiples of 2 such as 24951, 24953, 24955, 24957, and so forth. The only way to view consecutive numbers is by elongating the DOM which is not possible because I have a chart above the DOM so my space is limited. How do I fix this issue? Thank you. http://www.sierrachart.com/image.php?Image=1531446307296.png |
[2018-07-13 02:22:44] |
You need to follow the instructions here: The Chart DOM Scale: Auto Scale the Chart DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
