Date/Time: Mon, 29 Apr 2024 07:21:43 +0000
Question about a Cumulative Study
View Count: 653
[2018-07-12 21:27:07] |
a Gem Tree - Posts: 60 |
I'm wondering if SC has a study that aggregates (+=) the difference between two objects (Ex: 2 MAs). I see that you have something similar - The ZigZag Aggregate-Volume Study... but I see nothing that aggregates the spread of two different objects. If you don't have anything like this tool (adding the historical differences between 2 objects for the last X bars), would this be something you might create in the future? Date Time Of Last Edit: 2018-07-12 21:27:57
[2018-07-12 21:45:45] |
Yes, the study you are looking for is called Summation of Study Subgraph - Periodic. You just have to create the difference in a different study first (look at Study Subgraphs Difference). The documentation for the Summation of Study Subgraph - Periodic can be found here: Summation of Study Subgraph - Periodic The documentation for the Study Subgraphs Difference can be found here: Study Subgraphs Subtract/Difference And just to help you out, we have attached an example of how you could put this together as a Study Collection using the difference of 2 Moving Averages with different lengths. You can find the information for how to load a study collection we provide here: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
CumulativeMovingAverageDiff.StdyCollct - Attached On 2018-07-12 21:45:22 UTC - Size: 37.3 KB - 272 views |
