Date/Time: Sat, 18 May 2024 06:22:48 +0000
BitMEX option, and symbol confusion
View Count: 733
[2018-07-10 17:29:13] |
User732080 - Posts: 2 |
What's the difference between the BitMEX Trading and BitMEX Trading Direct services? Also, in setting up the Bitcoin-USD symbol for trading on BitMEX (not the testnet), I don't see XBTUSD as an option. I only see: .XBTUSDPI2H-BMEX, .XBTUSDPI8H-BMEX, and .XBTUSDPI-BMEX. Please advise. Date Time Of Last Edit: 2018-07-10 19:05:20
[2018-07-10 19:40:08] |
You need to use the BitMex Trading Direct service. Here are the complete instructions: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SetupInstructions The symbol you want is XBTUSD-BMEX. It is listed after using Get Symbols as documented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
