Date/Time: Fri, 03 May 2024 11:13:27 +0000
Moving Ave.
View Count: 590
[2018-07-02 19:44:07] |
User72965 - Posts: 114 |
How do I find the 100 200 day moving ave.?? Thx Gene |
[2018-07-04 21:07:40] |
You just need to use the Moving Average-Simple study and set the Length to what you require. Refer to: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-04 21:08:12
