Date/Time: Mon, 29 Apr 2024 14:27:24 +0000
contrat future vstoxx v2tx/ interactivbrokers
View Count: 890
[2018-06-29 09:03:11] |
User751137 - Posts: 2 |
hello can you add future (interactivbrokers) contract vstoxx (v2tx) eurex thank you.
vstoxx.PNG / V - Attached On 2018-06-29 09:01:05 UTC - Size: 90.38 KB - 297 views |
[2018-06-30 09:00:48] |
This has now been added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-30 09:02:24
[2018-06-30 22:32:52] |
ticinotrader - Posts: 378 |
Dear Support, Can you also please add support to the Interactive Brokers symbol of the Eurex Euro Stoxx Banks Index futures? Its IB symbol code is SX7E (the equivalent of the FAU18 of the Barchart symbol). Thank you. |
[2018-07-09 19:53:25] |
Yes. We will make sure this is done.
[2018-07-11 07:47:39] |
hello why monthly deadlines are not visible on future v2tx? thank you very good day |
Capture v2tx.PNG / V - Attached On 2018-07-11 07:47:11 UTC - Size: 92.33 KB - 293 views |
[2018-07-11 22:27:30] |
We will list all months for this contract now. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-11 14:13:54] |
Dear Support, Can you please check the V2TX Interactive Brokers symbol when using the Sierrachart Datafeed? I'm using the 'Allow support for SC datafeed' and subscribed to EUREX Realtime, but when trying to open any chart or DOM for the given symbol (V2TX), I receive the IB error message: not subscribed to DTB, and no chart is displayed (Download Failed). I am not subscribed to any data at IB but using your realtime feed. When I am connected directly to the SC datafeed, all the charts and DOMs come up and update correctly for this product (for example DVG19) Thank you. |
[2019-01-11 22:42:56] |
