Date/Time: Thu, 02 May 2024 16:19:56 +0000
Spreadsheet
View Count: 580
[2018-06-27 18:17:58] |
User123235 - Posts: 46 |
Hi, how one go about hiding, removing zero's from a data column so I wont get a DIV/0 error on a formula? I searched all threads and no luck, thanks in advance. |
[2018-06-27 19:26:11] |
Usually the way this would be solved is to use the IF function which can use a different formula in the case where a particular cell it is referencing, is 0. Refer to: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#IF_Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
