Date/Time: Mon, 06 May 2024 20:54:37 +0000
Using shortcut menu to hide/unhide studies
View Count: 1467
[2018-06-24 23:47:48] |
Chuck6475 - Posts: 24 |
I love the ability to hide and unhide studies using the shortcut menu, but is there a way to only unhide those that were active prior. I use Study angle as a parameter in deciding the Trend of the chart. I don't need it for anything but the angle calculation. I have its output "hidden" and the study "hidden", but when I use the shortcuts to hide the rest of the studies and then unhide them it reappears. How can I get the benefit of the angle data but not have the study reappear. Thanks, |
[2018-06-26 16:21:46] |
John - SC Support - Posts: 31401 |
Refer to the following documentation for how to do this: Chart Studies: Hiding Subgraphs to Prevent Display of Study when Unhiding Studies Once you have the subgraphs set to Ignore, you can then access the information using Text Display For Study to display the information on the graph, or you can just use the Crosshair with the Tools Value Window to view the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
