Date/Time: Wed, 01 May 2024 23:03:13 +0000
Vertical lines (or zones)
View Count: 1003
[2018-06-24 20:28:48] |
User606491 - Posts: 164 |
Can I use the spreadsheet study, to create a VERTICAL line demarcated by a high and low price? For example, I want to draw a vertical line for a zone (P1-P2) above current price and another zone (P3-P4) below the current price. Can this be done via the subgraph draw-styles? Do you recommend another way of doing this?
[2018-06-24 20:37:35] |
The Horizontal lines study would be perfect but I would like the demarcating values to be derived from a spreadsheet (i.e. automated) so that I don't have to manually enter levels for each zone and for each chart. Horizontal Lines |
[2018-06-25 14:40:28] |
Yes, the Spreadsheet Study can be used for this purpose but you would have to determine the formulas. You would need to use this particular set of Draw Styles: Chart Studies: Bar Top (ACSIL: DRAWSTYLE_BAR_TOP) and Bar Bottom (ACSIL: DRAWSTYLE_BAR_BOTTOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-25 14:52:50] |
Exactly what I am looking for. this works. thank you.
