Date/Time: Fri, 03 May 2024 11:44:03 +0000
[User Discussion] - USDRUB not loading on SC Forex Data
View Count: 625
[2018-06-20 10:55:47] |
Viacheslav Malafeev - Posts: 88 |
There is a message showing that loading is complete, however nothing is loaded. This has been the case for a while. Other symbols are loading OK. "delete all data and donwload" won't help. http://www.sierrachart.com/image.php?Image=1529492111802.png |
[2018-06-20 12:23:46] |
This symbol has not been supported for years now. We cannot provide further help with this. But you could try using the symbol ^USDRUB Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-20 14:12:08] |
Download failed. Is this a matter of negotiation with FXCM to support USDRUB again? If so, can anything be done? |
[2018-06-21 05:36:55] |
LMAX supports this symbol. Refer to: http://www.sierrachart.com/index.php?page=doc/LMAX.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
