Date/Time: Fri, 03 May 2024 09:05:21 +0000
Text messages on chart
View Count: 2537
[2018-06-19 22:43:48] |
Chuck6475 - Posts: 24 |
I would like to display TEXT on the chart. Specifically a Prefix + "UP" or "DOWN". The condition of the text could be the result of a "true" from an alert of another study. The ideal situation would be for the resulting text to appear in a Stationary Text box where font and size can be easily adjusted. Can this be done? |
[2018-06-20 03:43:12] |
You can use this Draw Style with the Color Bar Based on Alert Condition study: Chart Studies: Text (ACSIL: DRAWSTYLE_TEXT) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-21 02:55:26] |
Thanks for the reply BUT I don't see how this solves my issue. My desire is to have a series of conditions to designate if the Trend is UP or Down and reflect that fact in writing on the chart. See image. Consider it a mock-up for what I'm trying to get to. http://www.sierrachart.com/image.php?Image=1529549525962.png Thanks again for the help. |
[2018-06-21 04:54:07] |
You need to custom program this using ACSIL: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php And then you need to use the text drawing tool: http://www.sierrachart.com/index.php?page=doc/ACSILDrawingTools.html Understand that we do not provide programming help. So we cannot help you with how to do this. In regards to our prior response here is the documentation for Color Bar Based on Alert Condition: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-21 04:55:30
[2018-06-21 11:42:25] |
Okay, thanks. There is so many studies that I wanted to make sure it would require programming before I decided to go down that route.
[2018-06-21 20:30:32] |
There might be a way using Text Display for Study in combination with Color Bar Based on Alert Condition. We just want to think about this a little.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-21 20:30:51
[2018-06-21 21:52:48] |
In the next version of Sierra Chart these new inputs will be available with the Text Display for Study study which will accomplish what you need: UseTextForNonZeroValue NonZeroValueText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-22 02:47:48] |
Perfect. Thanks for following through. Looking forward to the next release.
[2018-06-26 05:07:39] |
Acro - Posts: 436 |
This is working well, thank you. Would it be possible for you to make these two settings available to the "Text Display for Study From Chart" also please ? That makes a really easy way to display text on chart B (eg shorter term) using eg trend detection on chart A (longer term). Thanks in advance |
[2018-06-27 12:12:00] |
Yes we can do this.
