Date/Time: Sun, 28 Apr 2024 08:13:36 +0000
Always on top function
View Count: 1919
[2018-06-14 14:08:04] |
User629089 - Posts: 93 |
Hi, I use the "Always on Top" function to have a chart in front and visible when overlapping another chart. When I take down SC's the AOT function seems to be disabled or isn't active when I bring SC's back up, and I have to set up those charts that I want to use this for again. Is it possible to have this AOT function permanent so I don't have to setup those charts again? Thanks |
[2018-06-14 18:55:09] |
This was fixed in a recent release. Upgrade to the most recent version following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-24 19:24:57] |
Hi, When I load SC's now, the charts that I have the "Always on top" checked appear on top of the other charts. This is great. But, if you were to click another chart that would overlap or cover those charts after loaded, that overlapping or covering will occur. In other words it works great initially when brought up but you have to click off and on the "Always on top" once up to get it to "stay" always on top. Is this correct? Also, upon updating to the new release of SC's it appears I've got "Version: 1762 32 bit". I'm quite sure I had a 64 bit version of SC's prior. Is this correct? Thanks |
[2018-06-25 07:59:56] |
This issue has been resolved. The current version is 1768. There are icons/shortcuts on your desktop for the 32-bit and 64-bit version. They are both installed at the same time. The 64-bit version shortcut on the desktop ends with _64. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-25 18:17:04] |
Hi, I'm now using SC's version 1768 64 bit and the same thing occurs that I described above. And that is when the "Always on Top" option is checked under the "Window" tab, those charts will appear on top when SC's is initially loaded. This is an improvement as before that wouldn't occur. However to get those charts to stay on top "Always on Top" has to be unchecked and rechecked under the "Windows" tab after everything is loaded. Any chart that overlaps or covers those charts that have the "Always on Top" checked will overlap or cover them. Any ideas? I don't have any idea what I could be doing wrong here as this is as simple a function as can be. Thanks |
[2018-06-26 06:53:18] |
Cavalry3162 - Posts: 523 |
same here... have upgraded to 1770 and the issue is still there...
[2018-06-26 08:47:47] |
We have consistently not been able to reproduce this. We will look at this a little more and see what we can do, but otherwise we really do not know why there would be a problem.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-26 08:48:15
[2018-06-26 09:03:15] |
you might try my (rithmic) chartbook...the vol profile and those relative volume / cumulative delta charts should be always on top but arent with 1770 and SierraChart_64.exe maybe it also has something to do with windows 10 1803? |
Tradestation_Rithmic.cht - Attached On 2018-06-26 09:01:21 UTC - Size: 787.9 KB - 244 views |
[2018-06-26 11:10:26] |
We did not test the Chartbook but we did find one problem and resolved it. Overall after we have went into this in depth, we realize that maintaining the Always on Top state is not so simple. There are a lot of considerations and the state can be lost very easily with even an operation such as a window tile operation. Also the Microsoft documentation on this is confusing and conflicting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-26 11:11:03
