Date/Time: Sat, 04 May 2024 23:46:32 +0000
Scroll Syncing Function
View Count: 2649
[2018-06-14 13:16:40] |
User311951 - Posts: 31 |
Hi there, I currently have 3 charts open for Crude Oil within 1 chartbook (i.e. the charts are all of the same instrument). Each chart is just a different duration or bar type e.g. one is a 4-range chart, 8-range chart and 5-min chart. When I scroll back in time on one chart, would it be possible to sync the three charts so that if I scroll back 3 days on my chart that is open, when I change tabs into the other two tabs, they will be at the same point in time? It would make my life a lot easier when backtesting. Thanks |
[2018-06-14 19:03:29] |
You need to use the Chart Linking option and set the Scroll Position as a linked item. You will find the documentation for this here: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
