Date/Time: Sun, 19 May 2024 14:46:51 +0000
Various issues
View Count: 983
[2018-06-12 16:20:03] |
User419467 - Posts: 13 |
Hi, I bought a 3 months level 5 subscription yesterday. I need to following connections - 1) Bitmex, 2) Thinkorswim, and 3) (through csv sheet with dde link) with a platform called Swordfish by a company called Estuary Solutions. I have the following issue at the moment: 1) Regarding Bitmex: Im not seeing bids and offers on the DOM screen - please see screenshot attached. It also seems that prices on sierra for .xbt-bmex is not updating the same time as Bitmex please see attached screenshots taken simultaneously. Please advise if i need to change settings etc? 2) Any advise on thinkorswim connection 3) Please let me know if something is wrong with the attached ".csv" file or where I can see an example. Or wether i can connect swordfish directly to sierra charts. Many thanks, Additionally the number bars study is not displaying anything for the xbt -bmex contract, im assuming bid and offer data is not being received from bitmex? What can I do about this issue, very excited about sierra charts but this real reason was to see order flow :-( https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=19847 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=19848 |
[2018-06-12 18:13:10] |
1. You are using the wrong symbol. You need to use XBTUSD-BMEX. Refer to: File Menu: Getting Symbols 2. Sierra Chart supports TD Ameritrade. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php 3. Sierra Chart cannot work with Excel files. It can work with text/CSV data though. Refer to: Text/CSV Data Format Sierra Chart definitely does not support Dynamic Data Exchange. That is so totally out of date and substandard. Beyond belief it is even still being used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-12 18:41:18
