Date/Time: Sun, 19 May 2024 16:09:21 +0000
Volume Profile not showing correctly since rollover
View Count: 1142
[2018-06-12 02:36:42] |
Camila - Posts: 21 |
Hi, On one of the charts in which I have a Volume Profile cummulative for the last 150 days,(to be shown on the right side of the chart) the chart is not showing correctly since I made the rollover. Instead of showing the volume profile, it shows daily volume profile, for each and every day of the last sessions. This used to work fine without any problems on rollover. I have checked the setup of the chart and it is ok. Thanks for your help Camila http://www.sierrachart.com/image.php?Image=1528770859403.png |
[2018-06-12 03:13:55] |
Go through the Volume by Price Input settings and make sure they are set correctly as you require: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#Settings And make sure there is enough data loaded into that chart. You will need to use the Continuous Futures Contract feature: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-12 15:27:27] |
HI, Yes, the contract is set to continuous contract always. And I have checked the settings but they are ok. I have another chart with another composite profile that is working ok. I compared the main settings and they are the same.. Don't know what may be happening thanks Camila |
[2018-06-12 18:09:11] |
Did you check the Input settings for the Volume by Price study, in particular this one: Volume By Price Study: Volume Graph Period Type (Volume Graph Period Type) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-13 04:20:04] |
Yes, I have it at "All bars in chart". And in the chart settings I have set the number of days to load in 150 days which is the period I want for the composite volume profile.
[2018-06-13 05:42:16] |
And do you see 150 days of data within the chart?
[2018-06-13 17:13:40] |
yes I do. http://www.sierrachart.com/image.php?Image=1528909997900.png |
[2018-06-13 19:15:08] |
We realize that the problem could be specific to the particular version you are running. Update to the latest prerelease following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
