Date/Time: Sun, 28 Apr 2024 00:06:25 +0000
Averaging Volume
View Count: 718
[2018-06-11 06:46:06] |
SithTrader - Posts: 6 |
Support, I'm looking to average a simple volume study by time, not by length or period. I've been able to over lay the SMA over the Volume study, but I have to put a set number in the box for it to reference back that many candles. I'd like to be able to average the volume (let's say) from 9am to 3pm. Time values that can be changed, so I can average the volume at different times of the day or night depending on when I trade. Any help would be greatly appreciated. Thank you! |
[2018-06-11 17:36:48] |
Perhaps you could use the Relative Volume study to accomplish what you want: Relative Volume See if that meets your requirements. The other thing is to create a custom study to do what you need: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-11 19:23:42] |
Sawtooth - Posts: 3980 |
Have a look at this thread: Reset a Moving Average at the beginnig of each day session ? |
