Date/Time: Wed, 01 May 2024 07:54:20 +0000
cumulative delta value on individual bar
View Count: 2405
[2018-06-08 16:07:27] |
User164231 - Posts: 278 |
Hi, Great work as usual Team SC. Just wondering; 1. Is it possible to show the value of CD on each CD candle? 2. Is there a study which I can use to display average value for the same period over past N amount of days? Thanks Team SC! |
[2018-06-08 19:22:47] |
1. Yes, use the Study Subgraph As Text Above/Below Bar study. You can find the documentation for this here: Study Subgraph Above/Below Bar as Text 2. Yes, use the Relative Volume study. You can find the documentation for this here: Relative Volume Be sure to look at the section entitled Basing Relative Volume Study on Another Study for Non-Volume Comparisons 2. You could also base a moving average on the Cumulative Delta Bars study. Refer to: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-08 19:23:36
[2018-06-09 08:48:12] |
Thank you so much. Re #1; is it possible to get rid of the two decimal value? Date Time Of Last Edit: 2018-06-11 13:03:11
Private File |
[2018-06-11 13:57:33] |
John - SC Support - Posts: 31240 |
Yes, just change the Value Format to what you want. You will find the documentation here: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-01 15:40:58] |
Ben000 - Posts: 11 |
I am seeing very big values in these numbers. Is it possible to us a multiplier for them? Say use a multiplier of 10.000 so that instead of a value of a million, i would see one hundred? Many thanks EDIT: achieved this with Volume multiplier in Chart settings Date Time Of Last Edit: 2022-05-02 10:35:07
