Date/Time: Sat, 27 Apr 2024 23:34:15 +0000
Day high low on price scale
View Count: 1566
[2018-06-07 02:35:28] |
User106180 - Posts: 88 |
Is it possible to add the option to have the day high and low on the right hand y-axis price scale? This is possible when I have the Trading Chart DOM On, but it would be great to have the same lines with it off. I appreciate that this is possible using the Daily OHLC study, but it places lines on the chart area. Thanks |
[2018-06-07 02:38:27] |
Acro - Posts: 436 |
You can do this with the daily OHLC study or even the High Low for Time Period or High Lowe for Extended Time Period. If you read the instructions you'll see you can choose to have on any kind of line or no line at all, a price marker in the Y axis and/or a name marker in Y axis or near the Y axis. Explore it and you will easily be able to achieve what you want |
[2018-06-07 23:12:50] |
Thanks Acro. As far as I can see the only way to get a marker only on the right hand y-axis price scale is to use the studies you mentioned above (I'm using 'High Low for Time Period'), and the draw style of 'Subgraph Name and Values Only'. This puts a highlighted box at the price of the high and low, but not a line. Sierra Charts - Would it be possible to add an option to have the value and/or just a line? |
[2018-06-08 04:05:00] |
Acro - Posts: 436 |
If you choose line you can still have the highlighted price box in the y axis. All "Subgraph Name and Values Only" does is allow you to have the price box without the line. If you want a line and price box choose "line", set the style and tick the box for the price marker |
[2018-06-08 04:07:18] |
Thanks Acro. I meant just a line within the y-axis price scale, not on the chart at all.
[2018-06-11 16:48:06] |
A line or other types of subgraph Draw Styles cannot be placed in the price scale. The best you can do is use this particular Draw Style which would close to what you want probably: Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE) (Line at Last Bar to Edge) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-11 17:01:42
