Date/Time: Sun, 28 Apr 2024 21:46:31 +0000
numbers bars
View Count: 549
[2018-05-31 18:16:15] |
natanibz - Posts: 131 |
Hello, is it possible in numbers bars to colour in a different colour only volume above a given value ? because i used a custom study (RTscanVolume) but now it doesn't work. I think for the fact of 64/32 bit Thanks |
[2018-05-31 19:43:12] |
Yes by using the Background Coloring Methods to compare to actual volume values. Refer to: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#BackgroundColoringMethods Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
