Date/Time: Sat, 27 Apr 2024 21:37:09 +0000
Renko Enhanced Charts
View Count: 2503
[2013-04-05 21:11:46] |
lpinkus - Posts: 6 |
Why do I need to refresh Renko Enchanced Charts, when I do not have to refresh plain Renko Charts. TY
[2013-04-05 21:30:25] |
The Renko Chart Enhanced study is no longer supported.
[2013-04-05 21:34:43] |
Thank You for your quick response. May I ask why they are not supported and do you know of any other charting service that does support Renko Enhanced charts. Thanks again
[2013-04-05 21:53:26] |
OK, we thought that you understood that there is a Renko setting directly in Chart >> Chart Settings. This is what you want to use: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#RenkoInTicks There is no need to use the Renko studies any longer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-05 22:08:40] |
Ok thanks, I just applied the setting. There were no setting before. So will Renko Enhance work now without constant refresh?
[2013-04-05 22:18:55] |
Yes. You should have no difficulties. You do not need the Renko Chart Enhanced study or any Renko study. Remove those from the chart. Just make certain you have tick by tick data: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-05 22:19:12
[2013-04-05 22:26:36] |
thank you, now I understand about the study and chart setting. I had study so I deleted it and now have chart setting. You're the best!!!
[2013-04-05 23:51:33] |
Hi again, Your Renko Charts do not look right. Your charts setting charts and the Renko study charts, that I must refresh, should look the same but the don't. Why? Your chart setting charts are showing multiple pivot unlike typical renko charts. TY
[2013-04-06 11:56:35] |
Hi, maybe my charts are outdated and I need to update to a newer version. I am using transact, because my chart setting charts are not renko charts. To many pivots, drawing bricks where typically they should not exist. I also can not adjust the time. TY
[2013-04-06 23:27:25] |
Sierra Chart - Max - Posts: 5597 |
From User: The chart below is a renko enhance STUDY using 90 min setting. This is what I was saying about having to refresh this chart. Without refreshing this chart would not look like this. But isn't nice? Your chart setting chart does not look like this. I also noticed on your chart setting chart I cannot change the time frame only the size of the bar. Is that correct? Sierra Chart Support |
image001.png / V - Attached On 2013-04-06 23:27:21 UTC - Size: 181.88 KB - 767 views |
[2013-04-09 04:52:05] |
The Renko in Ticks setting found in Chart >> Chart Settings produces very accurate Renko bars when used with tick by tick data. The reason when using the Renko study that you probably have to perform a recalculation is because the underlying bars are 90 minutes. The Renko study is not going to function correctly with an underlying bar duration that long. There simply is no support for using a long time duration underlying bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-09 04:52:51
