Date/Time: Thu, 02 May 2024 06:18:31 +0000
Using Sierra Charts on multiple computers
View Count: 4021
[2018-05-22 23:00:04] |
brenanstewart - Posts: 28 |
I am using Interactive Brokers as my source for data. They will only let me have one Trader Workstation open at a time. I want to have sierra charts working on both of my computers. How can I see the same feed on both computers?
[2018-05-23 01:40:34] |
We see you are using the Sierra Chart Exchange Data Feed. So what you will want to do is install Sierra Chart on each of your computers and then follow the procedure here for using the Sierra Chart Exchange Data Feed and verify you have a trading account once each month: Sierra Chart Exchange Data Feed: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you also want to use the data feed on two copies of Sierra Chart at the same time you will need to activate a second real-time connection here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-23 13:47:30] |
Do I have to pay an additional monthly fee in order to use Sierra Chart with real time data from both of my computers?
[2018-05-23 17:08:23] |
Yes, you will need to activate an additional Real-Time Data Connection here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#DataConnections Since you are using the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-23 17:08:37
[2019-04-22 21:03:19] |
User401511 - Posts: 33 |
Hi, Can I use One SC data feed on two different computers if they ARE NOT being used at the same time? Use one computer when at the office and switch to laptop when mobile. Thanks. |
[2019-04-22 21:57:42] |
Yes.
[2020-01-16 21:24:16] |
User353062 - Posts: 26 |
I have installed SC for my work and home PC. When I made a trade on my home PC, it does not show the live results in trade activity at my work PC? It does not sync trade activity between home and work PC. Is there a way to solve this?
[2020-01-16 21:54:17] |
The solution to this is to use this service which maintains long-term historical order fill history on the server and is provided to all installations of Sierra Chart set to use the Sierra Chart order routing service: Sierra Chart / Trading Technologies Futures Order Routing Service Also update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
