Date/Time: Sun, 05 May 2024 05:41:08 +0000
Color Bar based on Bid or Ask volume Trades
View Count: 1608
[2018-05-19 21:44:09] |
User508406 - Posts: 6 |
Hi there, I am able to color bars based on bid or ask volume, but when I got to use bid or ask trades, it just colors all the bars. I am able to color based on total # of trades, but would like to color based on Bid trades and ask trades separately. Is that possible? Thanks, AG |
[2018-05-21 18:08:06] |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Most likely Sierra Chart is not currently set for a tick by tick configuration and this is the reason for the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-21 18:08:41
[2018-05-21 19:56:28] |
Actually, exactly how are you referencing this?: bid or ask trades
And are you referring to the number of trades at the bid or ask? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-21 19:56:36
[2018-05-21 21:01:34] |
Yes, I am set to 1 tick. Attached is my issue. When I use the the "number of trades" study, the color bar above/below options matches up with a "# of trades" option.. When I put on "number of trades bid", or "number or trades ask", there is no option to match on the color bar above/below study. "# of trades", or "bid volume", or "ask volume" do not work or match. if there is NO solution here, I am looking for a study that can show me small trades, or the amount of small trades per bar. Can you reccomned one? Thanks |
Number of Trades.png / V - Attached On 2018-05-21 20:53:15 UTC - Size: 2.07 KB - 322 views #ofTrades.png / V - Attached On 2018-05-21 20:54:33 UTC - Size: 33.25 KB - 288 views ColorBarOptions.png / V - Attached On 2018-05-21 20:55:14 UTC - Size: 4.41 KB - 297 views |
[2018-05-22 05:11:07] |
We would have to test this, but the solution for this is to base that particular Color Bar study on the Number of Trades-Ask or Bid study: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-07 21:51:19] |
Tried the Above. Still not working. It works for bid and ask volume perfect though.
BidTradesAskTradesColor.png / V - Attached On 2018-06-07 21:50:51 UTC - Size: 112.37 KB - 324 views |
