Date/Time: Sat, 18 May 2024 15:24:36 +0000
Problems Installing Sierra Software
View Count: 577
[2018-05-19 13:37:28] |
User307403 - Posts: 1 |
I have a laptop with Windows 10. I have tried to install the Sierra Software but it won't install. I have disabled my ESET Security but it makes no difference. The message I get is :- Sierra Chart Installer Maximum number of retries encountered. Refer to log. Download cancelled. Press "Install" to retry. OK I have pressed "Install" several times with no luck. Any ideas what I can do? N.B. I am a blonde pensioner and whilst I know my way around a computer I am not really a techie. Thanks to you all. |
[2018-05-19 16:25:47] |
We apologize for the issue. This has been resolved. Try installing Sierra Chart again using the same method you did previously.
