Date/Time: Sun, 28 Apr 2024 15:02:03 +0000
Question: Profile of an Indicator?
View Count: 1201
[2018-05-15 13:06:45] |
RonW - Posts: 103 |
Is there the ability to, or the possibility of adding the ability to, display a Profile on an indicator? Investor R/T has this. For example, one could add the Bar Difference study to a daily chart to see daily ranges. Then, one could add a profile of this study to see the cumulative distribution of these ranges, getting more information than from just a moving average. I'm interested in your feedback. Thanks! |
[2018-05-15 18:22:15] |
There are the Horizontal Profile Draw Styles: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle_HorizontalProfile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-14 12:30:01] |
chart_warrior - Posts: 96 |
Can you please elaborate on how you would add it? I am also interested and here is a reference picture, look at the bottom 2 regions, they have a profile based on the volume and range. |
ft71escomposite161011140931.png / V - Attached On 2018-06-14 12:29:21 UTC - Size: 112.88 KB - 455 views |
[2018-06-14 19:12:44] |
At this point it is safest for us to say that what you are looking for is not supported. You could try using the Subgraph >>Draw Style referenced in our prior post. Here is the setting for this: Chart Studies: Subgraphs Tab >> Draw Style We will not provide any further support on this because inevitably you are going to come back saying that it is not what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-14 19:13:44
