Date/Time: Sun, 19 May 2024 04:11:01 +0000
Numbers bar graphics bug
View Count: 850
[2018-05-13 14:20:27] |
User308138 - Posts: 17 |
look at the attach..
numberbars.jpg / V - Attached On 2018-05-13 14:20:07 UTC - Size: 530.23 KB - 298 views |
[2018-05-13 20:46:08] |
To solve this, follow the instructions here: Numbers Bars: Adjusting Tick Size For Larger Increment And refer to: Numbers Bars: Scaling a Numbers Bars Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
