Date/Time: Wed, 15 May 2024 04:18:17 +0000
Spreadsheet Study not showing studies
View Count: 1006
[2018-05-13 07:59:35] |
User787778 - Posts: 139 |
When I start a new chart and add a moving average study and spreadsheet study to the chart, the MA is not reflected in the spreadsheet the the columns after the formula columns. Thanks in advance
Spreadsheet 130518.docx - Attached On 2018-05-13 07:56:26 UTC - Size: 164.13 KB - 254 views |
[2018-05-14 20:22:31] |
Be sure the following two items are Enabled for the Study itself and the Study Subgraphs of the study: Chart Studies: Settings and Inputs Tab >> Include in Spreadsheet Chart Studies: Subgraphs Tab >> Include in Spreadsheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-14 23:01:10] |
I loaded 10 different MA's onto a chart. MA's 1,2,6,7,9 and 10 had "Include in Spreadsheet" checked as default. I then checked 3,4,5,8 "Include in Spreadsheet" so that all the MA's should be included in the spreadsheet. Only 1,2,6,7,9 and 10 had values in the spreadsheet, while there was a heading, without values for MA's 3,4,5 and 8. There was no empty column after MA's 3,4,5 and 8, like there should have been. I updated to version 1745 without any change. |
Private File |
[2018-05-15 00:06:38] |
Make sure this option is also enabled for each of the Subgraphs of all of those Moving Average studies: Chart Studies: Subgraphs Tab >> Include in Spreadsheet It is a different setting on the Subgraphs tab. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-15 00:06:57
