Date/Time: Fri, 03 May 2024 04:36:31 +0000
DOM improvement
View Count: 821
[2018-05-12 22:28:56] |
User495158 - Posts: 106 |
Hello again! Firstly, I would like to thank you for making such a great trading platform. It has been just a week since I installed it but I'm already a fan of it. Some things I noted on TT's MD trader that would make DOM trader even better (screenshot included): 1. add the option to show OHLC on top of the trading window 2. make the trading window smaller. this is really important because even the compact version is taking too much space. 3. make working orders and positions smaller. again, this is very important in my opinion. no need to have stop order labeled "stop" or limit order "lmt" when it can be "s" and l". also, the option to customize fonts just for orders and positions would be greatly appreciated. 4. add different background color for prices which have been trading since the beginning of the session (or set period). 5. possibly add the option to easily add labels or lines to mark some areas. Thank you! |
[2018-05-14 23:03:45] |
We will follow up on this in the next couple of days.
[2018-06-01 04:23:39] |
1. Eventually this will come. For now use Window >> Current Quote Window. 2. This is something being considered. 3. Refer to: Chart Trading and the Chart DOM: Enabling Display of Orders and Trade Position, and Configuration of Orders and Trade Position Display 5. You can use the Stationary Text tool for this: Chart Drawing Tools: Type Text | Stationary Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-01 04:24:12
