Date/Time: Sun, 28 Apr 2024 20:23:21 +0000
running 2 separate sc
View Count: 1399
[2018-05-07 11:03:55] |
User875891 - Posts: 63 |
is it possible to run 2 completely separate sc platforms? I have an existing platform which trades thru amp I would like to have another that trades thru IB for various legal reasons I cannot have the IB account transferred to amp Date Time Of Last Edit: 2018-05-07 11:20:50
[2018-05-07 17:21:15] |
Sierra Chart - Max - Posts: 5597 |
1. Yes, you can run multiple and separate Sierra Chart instances. Refer to: Using Multiple Data and Trading Services at the Same Time 2. You need a Direct Sierra Chart Account to use IB. When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support Date Time Of Last Edit: 2018-05-07 18:45:26
[2018-05-07 17:44:43] |
To be clear I can maintain my sc/amp trading package for the single account but would need to subscribe directly to sc for the sc/ib account? There would be no conflict? I would be able to trade off 2 different trade windows? T |
[2018-05-07 18:38:08] |
Yes.There would be no conflict? Definitively no conflict.I would be able to trade off 2 different trade windows? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-07 18:38:28
[2018-05-08 21:26:55] |
Cant seem to get it to work
[2018-05-08 23:28:30] |
We need to have more of an understanding of this. Did you install another copy of Sierra Chart following the instructions here?: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-09 11:15:39] |
i did install another copy but it reverts back to by existing account
Date Time Of Last Edit: 2018-05-09 12:24:12
[2018-05-09 18:52:37] |
Did you create another Sierra Chart account separate from your AMP account? If so, follow the instructions here to use it with the other copy of Sierra Chart: http://www.sierrachart.com/index.php?page=doc/LoginInstructions.php#DifferentAccountName Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
