Date/Time: Sun, 19 May 2024 01:11:34 +0000
CME's Brent symbol not pulling down historical
View Count: 1166
[2018-05-04 08:04:53] |
Adam - Posts: 141 |
Hi i have moved from CQG to CTS and i have noticed that the CME brent BZ is not pulling down any data in the current month (apart from current day) see video clip below i made. http://somup.com/cFhfjeVGXq |
[2018-05-04 15:16:14] |
The current month is July and this is what we see: http://www.sierrachart.com/image.php?Image=1525446939589.png Let us know if you are having any trouble with the July BZ contract. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-04 15:22:54] |
Adam - Posts: 141 |
Im on july also The gap is is from the end of april to Thursday. But i know the gap on monday will be to Friday its not holding new data for the montth of May (holds the current fine as per you 1 min chart and the one attached) but it wont hold anything previous to that Adam |
2018-05-04_16h20_40.png / V - Attached On 2018-05-04 15:21:22 UTC - Size: 64.38 KB - 369 views |
[2018-05-04 16:04:24] |
That is not what we see but we do not have the Continuous Futures Contract option enabled: http://www.sierrachart.com/image.php?Image=1525648906735.png Follow the instructions here to re-download the data: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-06 23:21:51
[2018-05-04 16:10:19] |
Adam - Posts: 141 |
Sorted thanks
