Date/Time: Sun, 19 May 2024 02:57:30 +0000
Global DOM re-centre
View Count: 572
[2018-05-02 16:22:34] |
User316855 - Posts: 7 |
Hi, Is there a way to re-centre all open or linked DOM's at the same time? I've searched this page Chart Trading and the Chart DOM: Re-Centering the Current Price but can't seem to find a solution. Thanks |
[2018-05-02 18:53:40] |
You need to use this command: http://www.sierrachart.com/index.php?page=doc/TradeMenu.html#ReCenterTradeDOMScales Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
