Date/Time: Tue, 14 May 2024 22:17:47 +0000
Chart templates and Study Collections when changing from 32 to 64 bit.
View Count: 695
[2018-04-26 09:17:26] |
User92573 - Posts: 489 |
Dear Support - I have countless Studies that are included in Study Collections. - I am now using the 1733 64 bit platform. - My chart study collections were created some time ago (1490/1669) and include 32 DLL studies. - I can still see all of the Studies included in the Study Collections although they all appear as "Custom DLL Study." However, they all "seem" to be working fine. My questions are: 1) Are the existing studies still working correctly, as before? 2) Is there a way to maintain the form/structure of all current Study Collections when changing to 64 Bit. For example can I simply re-compile the existing .cpp as a 64 bit DLL, "without" changing any naming conventions, and then replace/overwrite the current 32 bit DLL's of the same name thereby, once again recovering the correct names to the current Study Collections. I have a lot of Chart books and many Study Collections. I'd prefer not to restructure and set them all up again - if it's at all possible. Many thanks Date Time Of Last Edit: 2018-04-26 09:20:53
[2018-04-26 15:27:40] |
Update re "Custom DLL Study" i.e. point (4) above. "I can still see all of the Studies included in the Study Collections although they all appear as "Custom DLL Study." However, they all "seem" to be working fine." The "Custom DLL Study" text string now reflects the correct name? ============================================================== The other questions above remain open when you have the time. Thank you. |
[2018-04-26 22:14:49] |
1) Are the existing studies still working correctly, as before? 2) Is there a way to maintain the form/structure of all current Study Collections when changing to 64 Bit. For example can I simply re-compile the existing .cpp as a 64 bit DLL, "without" changing any naming conventions, and then replace/overwrite the current 32 bit DLL's of the same name thereby, once again recovering the correct names to the current Study Collections. Yes but even if the DLL name has _64 at the end that will not be a problem."I can still see all of the Studies included in the Study Collections although they all appear as "Custom DLL Study." However, they all "seem" to be working fine." Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
