Date/Time: Sun, 05 May 2024 03:02:49 +0000
TPO Profile study on a point and figure bar period type chart
View Count: 868
[2018-04-25 19:14:35] |
Programming_autotrading_phonesup - Posts: 59 |
Hi support, When I apply the TPO study on a 1-6 Point and Figure bar period the chart seems to reload twice and switch back to a minute based chart. What I try to re-create is the chart in the screenshot attached. What I do wrong? |
Selectie_026.png / V - Attached On 2018-04-25 19:13:21 UTC - Size: 103.04 KB - 315 views |
[2018-04-25 21:35:39] |
That looks like a Numbers Bars chart and not a TPO Profile chart. Refer to the documentation here for the Numbers Bars study: Numbers Bars It looks like the numbers bars have been set to not display any text in them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-09 03:25:07] |
kevorkcapital - Posts: 2 |
Is it possible to create a TPO chart based on point and figure x and O instead of the usual 30 min time based bars?
[2023-05-09 08:13:37] |
ticinotrader - Posts: 378 |
@kevorcapital Please drop me a message through my site and I will provide extra details/options on non-traditional TPO profiles and 'TPO look-alikes' based on non-time based periods. There are already many posts on my site dealing with this topic. |
[2023-05-09 08:44:38] |
Sierra_Chart Engineering - Posts: 14224 |
This is not supported in Sierra Chart. If there is a way to do this, the above user can help. But we would not know how.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-09 08:44:46
