Date/Time: Thu, 02 May 2024 02:11:05 +0000
Volume moving average
View Count: 2366
[2018-04-24 21:18:28] |
User669396 - Posts: 7 |
Hi, can I get a moving average placed onto the volume study to show the average for the say the last 260 periods ??
[2018-04-25 04:52:17] |
Refer to the Based On Setting here: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-25 04:52:25
[2018-07-05 09:58:11] |
User924725 - Posts: 26 |
Is there a way for the moving average applied to the volume study to reset at start of each trading day?
[2018-07-05 10:52:39] |
Look at using the Moving Average-Rolling High Accuracy study to have the ability to reset at each trading day.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-05 10:52:57
