Date/Time: Mon, 06 May 2024 15:06:04 +0000
Number Bar Offset Question Please...
View Count: 1160
[2018-04-24 03:14:44] |
Quantico - Posts: 45 |
I've looked but cannot find a way to permanently offset price x number of bars from the right edge of the chart. Yes I can drag the bars to the left or use the down button key to temporarily adjust them to the left but they ultimately crowd up against the right side of the chart. Its a simple thing I'm sure but as a Norwegian I'm known to be strong, not smart. Thank you for all the thankless tasks you perform on a daily basis. Hopefully you are well rewarded. Date Time Of Last Edit: 2018-04-24 03:16:08
[2018-04-24 05:17:39] |
This is explained here: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
