Date/Time: Fri, 17 May 2024 19:55:46 +0000
[Programming Help] - Incorrect symbol fromat for XAUUSD and XAGUSD with IB
View Count: 1019
[2018-04-20 06:50:34] |
User841591 - Posts: 42 |
I want to trade XAUUSD and XAGUSD with IB and simply pick these symbols from CFD category. However, when I place order, I got the error message below. Could u provide the correct symbol format for the spot Gold/Silver for IB trading service? Symbol Error - (unknown symbol with ID 304) is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-20 14:47:15 |
[2018-04-20 22:21:29] |
Refer to the Interactive Brokers CFD symbol format here: Interactive Brokers Symbols: CFD Format You cannot use the symbols that you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-20 23:55:37
