Date/Time: Sat, 04 May 2024 13:51:08 +0000
Adding price Level to Horizontal Line
View Count: 2016
[2018-04-18 23:43:13] |
User373489 - Posts: 9 |
Can you please tell me why the option to add a price level to a horizontal line is grayed out? I have package 3 through AMP futures. Thank you, |
[2018-04-19 04:23:40] |
Do you mean in the Tool Configuration window for the Horizontal Line tool?
[2018-04-19 11:37:30] |
Yes, If I go to "Tools" >> "Tool Config">> "Line Config" > Under the tab "Labels" all of the options but the bottom two are grayed out.
[2018-04-19 14:16:13] |
John - SC Support - Posts: 31362 |
The option for displaying the Price is not available with the Line tool. We recently made some updates to remove the display of items that could not be turned on/off rather than just having them grayed out and unavailable. The ability to put a Price on a Horizontal Line is still available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-19 19:47:27] |
You need to use the Chart Calculator tool instead: Chart Drawing Tools: Chart Calculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
