Date/Time: Sat, 27 Apr 2024 14:48:16 +0000
I'm in China ,how to set symbol's RTH?
View Count: 599
[2018-04-18 16:11:19] |
Diana - Posts: 42 |
For example, CL, how to set? or there will be a nymex energy RTH option that I can set? I'm in China,so there will be no summer or winter time, maybe difficult to synchonize the time. |
[2018-04-18 22:57:32] |
Here are the instructions: Chart Session Times You can set the Time Zone in Sierra Chart (Globally or for a single chart) to US Central Time or US Eastern Time, and this will allow you to have a time zone matching the session times: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-18 23:00:32
