Date/Time: Sat, 04 May 2024 05:38:22 +0000
TICK-NYSE & NISS-NYSE at the open
View Count: 1075
[2018-04-13 14:03:30] |
Glenn Infinity - Posts: 103 |
I have a customer that is getting different values for these market stats on 2 and 5 minute time frames From thinkorswim & tradestation. Do you have any idea why that may happen? is there something he can manipulate to correct this?
[2018-04-13 17:51:57] |
There is no problem to begin with and in our research and experience we can definitively say that other sources are wrong at the open if they differ significantly than the Sierra Chart market statistics. Refer to: Sierra Chart Market Statistics: Market Statistics Calculations Compared to Other Data Services Sierra Chart should be considered the authoritative source on US market statistics. This has been verified time and time again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-13 17:52:25
[2018-04-13 22:28:50] |
Here is the specific section in regards to the TICK value at the open: Sierra Chart Market Statistics: Opening TICK Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-13 22:28:58
