Date/Time: Tue, 07 May 2024 04:01:24 +0000
help for a very simple study
View Count: 606
[2018-04-06 06:38:16] |
User538995 - Posts: 11 |
Hello, I have a study that draws a line and I would like another study that follows the same line of the first study but 1.5 ticks above. |
[2018-04-06 11:46:27] |
Zdislav - Posts: 73 |
Simply add a study called "Spreadsheet Formula" and set the formula: id1.sg1+1.5*ticksize Z. |
[2018-04-06 13:07:33] |
don't works.
[2018-04-06 13:37:57] |
nicktrader - Posts: 665 |
I don't know what study you are using for drawing the line but maybe the study "Bands/ Envelope" is helpful.
[2018-04-06 18:00:35] |
The Spreadsheet Formula study will work. Be sure that you update the ID1.SG1 part of the formula to match the study that you are using to draw the line. For information on how to reference the Study Subgraphs, refer to: Study/Chart Alerts And Scanning: Referencing Study Subgraphs Documentation for Spreadsheet Formula study: Spreadsheet Formula You can also use the Study Subgraph Add study which would be the most efficient way: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-06 18:02:04
