Date/Time: Sat, 18 May 2024 23:29:52 +0000
Accurate Ration Chart - Moving Average Displays Zeros
View Count: 668
[2018-04-05 12:07:14] |
CarlRostron - Posts: 80 |
With regards to: I have followed the instructions and it all works fine. However, I plot a moving average against the Spread, and I get zeros on the Moving Average on the front end of the chart which affects my scale. See image attached. Is there anything I can do to fix it at all please? Thanks for your help |
Capture.PNG / V - Attached On 2018-04-05 12:06:07 UTC - Size: 36.29 KB - 243 views |
[2018-04-05 12:09:30] |
Sorry, I have just seen the Moving Average Simple Skip Zeroes study and that has fixed it
[2018-04-05 19:14:54] |
Yes, you will need to use that study. We will update the documentation in regards to this.
