Date/Time: Mon, 29 Apr 2024 08:37:31 +0000
Draw Lines Globally
View Count: 1072
[2018-04-03 23:58:50] |
User375840 - Posts: 7 |
Is there a way to LINK Horizontal lines across All charts of the SAME symbol? (example) If I draw a line on my ES 2000 Tick chart at 2610.25, I'd like the line to copy on my 1000 ES Tick chart and my 5 minute ES chart at the same price of 2610.25 |
[2018-04-04 01:53:08] |
Yes. Refer to: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-12 04:17:26] |
User504477 - Posts: 14 |
Can this be done in a custom study? Meaning if a study draws a horizontal line on the higher time frame, the line should appear on all the linked charts. I checked the documentation and searched around but didn't find any info on this. |
[2024-02-12 19:53:35] |
By default, drawings that are drawn from a custom study are not copied. You would need to set the line to be "User Drawn" and you have to set it to be allowed to be copied. Refer to the following: Using Drawing Tools From an Advanced Custom Study: s_UseTool::AllowCopyToOtherCharts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-13 15:54:50] |
TY! I guess it won't copy the drawings automatically once enabled and will have to be done manually?
[2024-02-13 17:54:29] |
You still have to use the option for copying chart drawings as defined here: Copying Chart Drawings from Other Charts Automatically And you have to make sure you enter them from the study in the proper way for the copy to work. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
