Date/Time: Mon, 29 Apr 2024 14:02:42 +0000
not appearing in spreadsheet
View Count: 823
[2018-03-31 23:38:49] |
Devil_On_WallStreet - Posts: 67 |
Zig Zag is not appearing in spreadsheets. YES I set additional outputs for spreadsheet to yes as well as check the include in spreadsheet box... I made sure in the spreadsheet study window that do not show subgraphs set to ignore was also set to NO... I have gone through changing different settings all with no luck. I have attached a CB and spreadsheet, the CB only contains a ZigZag and a spreadsheet study |
HELP.Cht - Attached On 2018-03-31 23:37:12 UTC - Size: 39.56 KB - 330 views Private File |
[2018-04-05 21:49:13] |
The problem is simply that the option for Include in Spreadsheet was disabled for each of the subgraphs. You can find the general documentation on this setting here: Chart Studies: Subgraphs Tab >> Include in Spreadsheet And we have updated the Zig Zag study documentation to refer to this even when the option for Additional Output for Spreadsheets has been set to Yes. You can find the documentation on this here: Zig Zag: Additional Output for Spreadsheets For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
