Date/Time: Tue, 07 May 2024 06:27:02 +0000
ten second chart freeze
View Count: 510
[2018-03-28 14:36:48] |
User14953 - Posts: 193 |
Throughout the day, Sierra Chart display window freezes for about ten seconds while an hourglass replaces the cursor. Notepad and other concurrent open windows work while this happens. Ten seconds and a hundred heartbeats later, the Sierra Chart crosshair cursor replaces the hourglass and it's off to the races once again. What can I do to minimize this? Thanks
[2018-03-28 16:27:22] |
It sounds like it might be what is explained here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.3 - Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
