Date/Time: Sun, 19 May 2024 14:29:56 +0000
[User Discussion] - Range Bars and Higher Time Frames
View Count: 952
[2018-03-27 09:33:52] |
User764908 - Posts: 1 |
Hi there, Can I create a Range Bar chart and then apply Donchian Channels from Higher Time Frame Range Bar charts. ie ...Create an 8 tic Range Bar chart and then apply Donchian channels from 16 and 32 tic Range Bar charts so that all the analysis is centered on the 8 tic chart. If possible, would this chart be stored and therefore continuous, or would it be lost every time the PC was closed and need to start again. many thanks Ian |
[2018-03-27 16:20:36] |
JoseyWales - Posts: 67 |
Look into the Study/Price Overlay indicator. Study/Price Overlay Study Create both charts and apply Study/Price Overlay to your 8 Tick Chart. Change the setting "Study to Overlay" to the higher timeframe chart's Donchain Channel, change chart region to region 1. Charts are stored in Chartbooks which can be saved and later reopened. File->Open Chartbook |
