Date/Time: Sun, 19 May 2024 20:36:35 +0000
Platform freezing
View Count: 507
[2018-03-27 00:32:47] |
User731023 - Posts: 128 |
Hi, I have been having issues with my platform freezing the last couple of days. I would have to reboot through task manager. I was on version 1689 and downloaded 1725 to see if it would help to no avail. Two questions please. 1. If you have indicators or studies hidden or ignored does it use the same amount of computer resources? 2. Is there a suggestion on how I can locate the problem? Thanks as always. PS This is the first time I have had a problem with this. My internet is 300 Mbps and I have I7 with 16GB so I am good there. Date Time Of Last Edit: 2018-03-27 00:37:15
[2018-03-27 00:39:39] |
Refer to help topic 30: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html 1. We cannot really answer this question without more information. But this is not really relevant anyway. 2. You could look at the calculation time of the studies: Chart Studies: Studies To Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-27 00:39:58
