Date/Time: Sat, 04 May 2024 19:48:05 +0000
Trading levels study
View Count: 1835
[2018-03-26 11:17:21] |
User182649 - Posts: 31 |
I have reviewed the documentation on this study. PLease advise as to how I get started. Thanks. |
[2018-03-27 04:50:45] |
Did you want to provide trading levels to other users or just for your own use?
[2018-03-27 17:10:34] |
User364365 - Posts: 1 |
Hi, I am a member of Convergent trading and would like to set up Trading Levels Study so that I can use FT71's Stalk Zones. thanks
[2018-03-27 18:27:45] |
The first thing to do is to contact Convergent trading about this request and if necessary they will contact us for instructions.
[2022-04-11 03:26:18] |
User547290 - Posts: 42 |
Hello, Wondering how to make the Stalk Zone file for myself so I can share the file and send my zones to another like convergent does. I have set levels on a chart and want to be able to have a file or spreadsheet that the chart refers to so I can share the file. I guess what I am wondering is what does Convergent use to do this? |
[2022-04-11 16:00:46] |
John - SC Support - Posts: 31362 |
We do not know if Convergent is using this option or not, but what is referred to above is the following study: Trading Levels If your levels are entered through a study (or group of studies), then you can share them using a Study Collection. Refer to the following: Study Collections Or you can share your entire Chartbook. Refer to the following: Chartbooks (Workspaces): Sharing a Chartbook with Another User or Copying it to Another Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
