Date/Time: Sat, 27 Apr 2024 20:40:57 +0000
Region data lines
View Count: 2409
[2018-03-22 15:42:54] |
User459170 - Posts: 262 |
Hi, I am not able to get the region data lines to show. The Advanced settings/Region Data line/State are set to visible. Thanks.
[2018-03-22 19:52:18] |
Here is the relevant documentation for this: Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-22 19:56:49] |
Please see my original post. I have already set this up, but still the line doesn't show up. Thanks .
[2018-03-22 21:38:40] |
OK, but just for the record what you describe definitely cannot be the case. What the specific problem is in your case is not known since we cannot see an image of the chart.
[2018-03-22 23:15:45] |
Please see this screenshot http://www.sierrachart.com/image.php?Image=1521760471831.png
[2018-03-23 08:18:10] |
JoseyWales - Posts: 67 |
The screenshot that you provided shows that both regions 1 & 2 Data Lines are being displayed. Maybe you are thinking of enabling the Horizontal Grid? If so, go to the Menubar->Chart->Horizontal Grid->All Regions. Or use shortcut Alt+Shift+H Chart Menu |
[2018-03-23 08:27:10] |
I also see that your Bar Difference Study is not showing the Input Values. If this is what you want, then go to the Bar Difference study settings, Subgraph tab and enable the checkbox "Display Input Values". https://www.sierrachart.com/index.php?page=doc/ChartStudies.html&CAID=def#DisplayInputValues |
[2018-03-23 16:06:35] |
Hi, I am probably calling it the wrong name. What I meant to ask was, is there a way to have a horizontal line that separates Region 1 and Region 2? Thanks P.S. Just found the answer, problem solved. It was the dividing lines that I wanted Chart Settings: Display Region Dividing Lines (Chart >> Chart Settings >> Grid menu) Date Time Of Last Edit: 2018-03-23 16:10:58
[2018-03-23 16:24:31] |
As far as I know there is no line that visually separates regions. On a side note, you can adjust the size of regions using this method: Working With Charts: Chart Window and Regions |
[2018-03-23 16:45:32] |
Hi Josey, there's a line that visually separates regions. It is called a Region Dividing Line. I have given you the link in my previous post, it works.
[2018-03-23 16:52:56] |
I didn't know about this, thank you for sharing it with me! Always finding out about features I didn't know Sierra Chart had.
Date Time Of Last Edit: 2018-03-23 16:57:52
[2018-03-23 17:07:58] |
Thanks very much for your help today Josey :) You have given me some additional info about Regions, thanks. Have a great day!
