Date/Time: Wed, 15 May 2024 21:07:14 +0000
Tails
View Count: 932
[2018-03-21 15:56:57] |
User921942 - Posts: 16 |
Can someone explain these tails? http://www.sierrachart.com/image.php?Image=1521647597297.png |
[2018-03-21 17:47:06] |
The first thing to do is to remove all studies from the chart and see if there any data errors with the underlying data itself. If so, refer to help topic 2.1: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1 Intraday Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-27 16:23:20] |
It doesnt work
[2018-03-27 18:23:52] |
What does not work?
[2018-04-11 09:57:31] |
ok its fine TPO settings and chart settings were not well accorded, thank you for your interest . Claude. |
